1 - 4 of 4 Posts
I just purchase a Sapphire X800 PRO VIVO and i just did a fresh install of Windows XP SP2. I install the nforce 5.10 drivers and the catalyst 4.12. My first question is how come i'm not able to see the temperature of my card with the ATI drivers? The overdrive option is not available.... My second question is that i saw alot of people on forums that are modding their x800 pro to xt-pe.... I installed atitool 0.22 and overclock the card to xt-pe speed (520-560) and a have no artifacts.... and i can see my temp with atitool... now i'm ready to flash my bios to a xt-pe with 16 pipes instead of 12... does anyone here ever did the mod? If yes, is it possible for you to give me the right procedures? The right flash utility to use and the right bios? And the lines i have to type in DOS mode? And the links for the utility and bios? Hope that someone can help me! It would be great!
Thanks
Carlo
AMD ATHLON XP-M 2600+ @ 2.65 Ghz
THERMALRIGHT SP-97 + Panaflo 92MM Ultra + ARCTIC SILVER 5
ABIT NF7-S WITH MANTA RAYs XT D26 MODDED BIOS @ 221 FSB
CORSAIR TWINX 2X512MB PC4000 @ 2.5-3-3-11
SAPPHIRE X800 PRO VIVO
2 X WD RAPTOR 36GB 10K RPM 8MB CACHE IN RAID 0
WD CAVIAR 200GB 7200 RPM 8MB CACHE
PIONEER DVD 16X SLOT
PIONEER A06 DVD BURNER
ENERMAX NOISETAKER 600W PSU
ANTEC PLUSVIEW1000AMG CASE + 5 ANTEC 80MM RED LED FANS
LG FLATRON 915FT PLUS
Yes i have one, i just need the correct procedure now.... i know i need the bios from gigabyte but the link to their website is broken.... can anyone provide me the direct link for each program i need... and the procedures?
Thanks
LG FLATRON 915FT PLUS[/QUOTE]
Thanks
[/QUOTE]
if u live in england but this months pc.gamer theres a fulls page at the back of the book explaining how to flash uyr v-bios and where to get the correct bios
hope this help rep me if i helped
1 - 4 of 4 Posts
