Modding 3 yr old HP case
1266 Views 11 Replies 9 Participants Last post by  Spritanium
I have an HP mid-tower case from an 3 yr old pavillion a1034n that I plan on re-using and modifying to house an AMD build for my sister. She is eventually going to become a techie like myself and wants to help with the build. My question is, should I just buy a cheapo case and use that or succumb to the modder in me and use the HP case. These are the parts I plan on putting in it:
Mobo: http://www.newegg.com/Product/Produc...82E16813128392
Processor: http://www.newegg.com/Product/Produc...82E16819103674
RAM: http://www.newegg.com/Product/Produc...82E16820227479
PSU: http://www.newegg.com/Product/Produc...82E16817341022
HDD: using a year old 250GB SATA drive
CD/DVD: using my left over drive from my last build
Cooling: http://www.newegg.com/Product/Produc...82E16835185093
http://www.newegg.com/Product/Produc...82E16835185049
Suggestions and ideas are welcome.
1 - 12 of 12 Posts
it depends if the hp case will fit all atx parts otherwise it won't work
I'd highly suggest against reusing the case. Very minimal air flow/management and space. Better off spending 30 dollars on some cheap-o
You could reuse the case with little to no modification as long as you use a mATX motherboard. Actually, a ATX board like you linked wouldn't even fit in that case.
orly?
http://www.overclock.net/case-mod-wo...-case-mod.html
Still using that case to this day.
It should. I did some research on the case and the only thing I may have issues with is the PSU, which should be easy enough to work around.
Originally Posted by slothfish
orly?
Pretty nice man O_O.
Nice work slothfish!! +rep for you. Thanks for the encouragement. I look forward to modding the crap out of this thing now. Not sure if I can make it as purdy as yours, but I'll try and post some pics of the build.
Sweet! Glad I was inspiring
. Don't be afraid to mod the hell out of stuff, every case has some potential to be awesome!
Here is the Antec 300 for $35 after the rebate. I wouldn't bother with the HP.
http://www.newegg.com/Product/Produc...-042-_-Product
orly?
Wow, cool mod.
Are those the thermaltake fans with the pci fan controller? I have one in my case, and I love it.
1 - 12 of 12 Posts
