For some unknown reason, I've decided to take the pump/res from my old WC setup and use it as a res only, instead. We'll see how it all fits when i get the other stuff, but, I was hoping I could have some input on this mod.
Here's a pic of the original item:
Here's a pic of the top:
And, of course, it opened up:
My idea is to remove the built in pump, and simply use it as a res. Why bother spending 20 bucks on a res, and another 15-20 on a flowmeter when I already have them? Just remove the old 400lph pump, throw in a piece of tubing to connect the backing to the res, and viola!
I'll be using a Swiftech 655 (not to be mounted in here, obviously) and swap out the hoses to 1/2id 5/8 od tygon for higher flow. I'm using a rad I already have, and I'm changing all of the barbs (even on the GTZ) to 1/2 silver barbs.
My question is: Should I run tubing straight in? or, should I just remove the pump and the 2 hoses and mount a single hose in between the backing and the res? Either solution will allow me to close it back up, I just think using the barb on the backing will allow me a little more flexibility in modifying the setup later.
Well, am I insane? or... does this look interesting, at least? Any constructive criticism would be appreciated.
I would like to know if that cooler master WC thingy takes up only 2 bays or if it takes up 3 bays. It looks cool BTW.
Yeah it will work. Why don't you replace the current pump with something better? I'm sure you'll be able to find a decent pump that will work great in the current config with minot to none modifications.
EDIT: i was thinking of something in this line: http://www.petrastechshop.com/dadencp12vin.html but i see the inet/outlet won't fit the config of the aquagat max. Maybe somebody can give a link to something similar, but with the inlet/outlets aligning to that of the res.
the res is OK, the pump looks like a DB-1 pump, which is a great little pump, not too powerful, but still a great little pump. if you run CPU only i'd just keep using that one as it is.
Yeah, it's not that powerful... only 400lph. That's why I ordered the 655. It does 1200lph and I figured while I'm at it, I'll jump up to 1/2in tubing to allow more flow. I wanted to build in the expandability now while keeping the even look of the "Cooler Master" res on a CM case. It just seems to fit.
But with the new pump, I'll be able to add on items later without worrying about having to upgrade the entire system. Maybe add a rad , or something.
Besides, being CPU only, it'll just keep it that much cooler!
yeah, i'd set the pump at setting 4 though... just a bit more silent and the pump itself will dump a little less heat in the water... put it on 5 when you upgrade to more blocks and rads.
Overclock.net
