1 - 6 of 6 Posts
Is it posible to flash x1600xt to x1800xl or xt?
X1600XT has almost the same core clock/memory as X1800XT!
... No.. totally different cores.
You always seem to ask questions about the imposible
The X1600XT only has 12 pipes on the core. There isnt any more on it.
Discussion Starter #4
Hey iam new to this side! You are 14 years old and you know more than you need too for your age!
lol I like computers alot so its like the only thing I actually try to learn about.
Yeah..my x700pro has higher clocks than the x850xtpe, but I can't flash that
as long as the card has the SAME marchitecture/core, you should be find flashing, but the x1600xt has a different memory bus and a different core (128-bit vs 256-bit, forgot the numbers for the cores)
1 - 6 of 6 Posts
