Hi,
Modmymods has clear coolant and a discount code for one free using coolant at checkout add 2 to cart one is free
Turns out modmymods uses x1 clear concentrate and local distilled water
It's only 8.99 per liter saving 5.00 at the least ! plus one for free is a great deal
https://modmymods.com/modmymods-modwater-pc-coolant-clear-1-liter-mod-0275.html
They also have 3/8-5/8" clear flexible pvc soft tubing 0.94 per foot made locally too is why I called actually seeing if it was as flexible as mayhems/... soft tubing they said yes
Plus non plaster tubing as well
https://modmymods.com/modmymods-3-8-id-x-5-8-od-flexible-pvc-tubing-crystal-clear-mod-0003.html
Edit on post 5 below
