Monitor Died time to buy a New one
327 Views 7 Replies 8 Participants Last post by  SVECobraR
My old monitor just died
. So its time to get a new one size does not matter as much as response time these are the specs i am looking for:
Fast response time 2ms preferred but i can go with 4ms
Must be dvi
22" or bigger is preferred
$250 Usd or less
I have looked around town at the electronic stores and this http://www.newegg.com/Product/Produc...82E16824236050 caught my eye it looked nice and looks like a great deal for the price.
Also http://www.newegg.com/Product/Produc...82E16824236051 caught my eye on newegg looks to be the same except higher Resolution and a hdmi port.
Any and all suggestions are welcome even if they don't match all the criteria above. Thanks
1 - 8 of 8 Posts
I just got mine today. It is this one and OH MY... What a monster. It looks great, but have not got to see it in action yet. It is 5ms
$249 shipped 24"
$249 shipped 24"
I second that, If you want a 22 inch in that range the HP w2207h is a good choice also
http://www.newegg.com/Product/Produc...82E16824176091
But it really depends on what your wanting to do with it. If your looking for more screen space or if your wanting a better quality panel. Asus has a good panel but I do believe that the HP has a better picture quality.
http://www.newegg.com/Product/Produc...82E16824009163 This is the one I'm getting in week or two, the only thing for you is that it isn't 2ms, but 5ms. Really isn't that big of a difference though.
I heard a good monitor is the LG L227WTG-PF:
http://www.newegg.com/Product/Produc...82E16824005109
It's supposed to have a great response time and an input lag of 0 ms. http://prad.de/en/monitore/review/20...wt-part12.html
And hence it's ideal for gaming.
I have this one , and i just love it . The picture quality is really nice, it's very bright and stylish. If you don't like the color you can get the black one instead. The only cons are it's a bit expensive and its not that stable
http://www.newegg.com/Product/Produc...01273&Tpk=t220
so whats the regular response time on the ToC series, specifically my T220?
1 - 8 of 8 Posts
