Monitor Display Problem
544 Views 9 Replies 5 Participants Last post by  Drackula2000
Sorry if this has been asked before but its really starting to annoy me.
Im using a AG Neovo 19inch non widescreen monitor, Im having this problem where the monitor seems to blur images to the right.
Ive uploaded a screenshot of the problem im having.
Ps. I dont think its a problem with resoloution as Im running at the monitors default and Ive also tried different ones.
Somebody before said something to do with the monitors phase but I tried changing this in the monitors control panel without it making any difference.
Help and advice would be much appreciated
Heres the photo link to the problem
http://i238.photobucket.com/albums/f...n1/desktop.png
also you before you say its something to do with windows7 I've rolled back to vista and i still have the problem.
1 - 10 of 10 Posts
That image is fine here, something is physically wrong with your monitor.
That's what i'm thinking. I see nothing wrong with that image. If you have a decent camera, take a photo and upload it for further diagnosis.
Ill do that now, thanks
Heres some pics with the camera
http://i238.photobucket.com/albums/f...1/DSCF2059.jpg - on the right you can see its blurred
http://i238.photobucket.com/albums/f...1/DSCF2060.jpg
from what i found, that is a bloody expensive monitor man! I would send it in for warranty, provided you a) have a replacement and b) it is new enough to still be covered. Since the image in your OP was fine, it is a physical problem, I think (I'm not a monitor genius).
You could also try a different cable (DVI/VGA/HDMI etc.)
I just did a search also, but im almost certain its not worth the amount most of those that came up on the search were. Its quite a cheap monitor.
anyone have any idea?
Have you tried adjusting your color settings and whatnot in your VGA controls? I know if my contrast is below 63% I get a really wierd flicker between diff shades of black.
Looks like ghosting. Is it under warranty still? I would start the RMA process soon.
1 - 10 of 10 Posts
