1 - 4 of 4 Posts
So I have a 5 years old 1080 60Hz TN monitor, and recently I decided to upgrade, but I got so confused on what to buy.
First I was thinking about the Asus PG279Q, but those apparently have massive QC problems and are risky.
Now I'm thinking about getting two different monitors (One for gaming, one for normal usage), I was like if I couldn't have a good gaming IPS monitor, why not buy a gaming TN + a normal IPS.
After some research I found Dell UP2716D and Dell S2716DG.
So my question is are these good monitors to get, or any one have better suggestions for me?
Thanks in Advance
Any reason you need IPS? If you just purely game you're probably just better off with TN's and 144hz.
Discussion Starter #4
Well honestly I've never used an IPS monitor, so I really wanted to try it. I might keep the IPS or just return it. Also I watch movies and shows on my PC, so good colors might be good to have.
Anyway, I already ordered both so I can try them side by side, hopefully none of them have defects.
1 - 4 of 4 Posts
