1 - 4 of 4 Posts
This monitor at work i'm using has a vibrating top left corner, think its possible I may be getting nauseous just staring at it. I'm guessing its interference from the nearby power supply socket and by nearby I mean 4 inches away. Anyone think this is the cause? Its a typical AC adapter power supply.
It might be a good idea to get a new monitor ...or a lead crotch protector if that's not an option.
EDIT:
Have you tried hitting Degause on the monitor? Maybe moving the monitor slightly or better yet move the AC adapter if you can.
Discussion Starter #4
Ok managed to shift it theres probably around 12 inches of space between the monitor and adapter. Seems to have solved the problem. Cheers guys.
1 - 4 of 4 Posts
