1 - 8 of 8 Posts
Hello,
I was just wondering how I would go about checking the temperature of my system components. Can that be achieved by software alone? or do I need specific hardware requirements? I was thinking about using one of those thermometers that are used for cooking turkeys... Not sure if that is a good idea or not.
I plan to just utilize fans (as in no liquid cooling) for a new build; however I fear that fans alone might not cut it. So I want to be able to check the temperatures when I put it together.
Any help is appreciated.
speedfan as well...or everest...
How can I tell if my BIOS supports system temperature monitoring?
I'm looking at a ASUS A8N32-SLI Deluxe Socket 939 NVIDIA nForce4 SLI X16 ATX AMD Motherboard right now and I do not see anything about temperature monitoring.
Someone said to buy one of these http://www.frozencpu.com/tmp-11.html.
I am still a bit confused. Sorry.
i believe that that board comes built with a temperature monitoring system but however plz take note that the tempreture reading u obtain is within a plus minus 5°C range...so take note of that....
and u do not need a separate temperature monitoring system unless u have a water cooling or phase change system and even then ur onboard temp monitoring system will be able to handle it so dont waste ur money....
1 - 8 of 8 Posts
