Originally Posted by shortfuse Mosfett controls the vcore voltage right? so the warmer the mossfet gets the more unstable voltage u get? im planning to rig a fan on my msi neo4 sli plat. would this help me with my vcore fluctuation? |
Yes, the MOSFET (1 T) is a transistor that contols the vcore.. Yea, I guess you can say the warmer the MOSFETs get, the more flux there is. It is recomended that you keep that temp under 50c, a fan isnt required, just some heatsinks w/some AS5. That is your cheapest solution, though you can get a fan.. |
Originally Posted by wowza Yes, the MOSFET (1 T) is a transistor that contols the vcore.. Yea, I guess you can say the warmer the MOSFETs get, the more flux there is. It is recomended that you keep that temp under 50c, a fan isnt required, just some heatsinks w/some AS5. That is your cheapest solution, though you can get a fan.. |
Originally Posted by MADMAX22 man i guess i had better get osme cooling on those puppies mine idle at like 50 to 60c and loads are high like 90c+ |
Originally Posted by shortfuse How can u tell the temps on mosfets? applying as5 on the heatsink on em mosfet is not an option for me its kindda hard to pull it out. |
Originally Posted by shortfuse By the way im using speed fan to monitor my temps. |
Originally Posted by pbasil1 sry to butt in... but if i uplaod a pic of my mobo can u show me the mosfets???? |
Originally Posted by wowza Does it list a PWM temp? if not, well, I don't think your motherboard has a temp sensor on the mosfets...Sounds like your going to have to remove the Heatsinks and manually put a temp diode on it... Let's see a pic and see if it is manageable to get the heatsinks off.. |
Originally Posted by MADMAX22 these are th mosfets circled in redish color, there may be more but you can tell they look like chips with really big legs and stand away from the mobo usually |
Originally Posted by shortfuse Nope doesnt say anything about PWM. ohh so pwm is the mosfet temps. been wondering what that was on my old dfi nf3. heres the best pic i can find cant really take a pic of my mobo i guess i just have to disassemble it again and look around further |
Originally Posted by wowza Nooo dont use epoxy!! That will do more damage than good..use some thermal compound (i prefer AS5)... that should make them stick good enough. |
