1 - 17 of 17 Posts
In this thread we will discuss the most consistent brands for all computer parts, including peripherals.
The brand can be specified for things like OCZ makes good SSD's but average PSU's. Model specific is ok too. Just make sure to specify.
Consistent doesn't mean it has to be consistently great, it can also be consistently bad.
I will be compiling the list in this post, that way people can easily use this as a resource for which brands are generally good.
This is for everything except processors, as there will just be a giant debate over which one is better, plus there isnt really any bad processors now adays, bad as in unreliable or poorly built. Basically just pick a processor from the last 2 -3 years and your good.
If something has an Asterisk * be sure to read the Asterisk section below for that product.
CASES
Great means
  • Great Airflow
  • Good Design
  • Mostly Steel/Aluminium, minimal Plastic
  • Sturdy
Average means
  • Decent Airflow
  • Alright design
  • Partially or mostly Plastic
Terrible means
  • Bad Airflow
  • Bad Design
  • Almost all Plastic or other breakable material
CONSISTENTLY GREAT
Coolermaster HAF series
Corsair
Silverstone
CONSISTENTLY AVERAGE
CONSISTENTLY TERRIBLE
FANS
Great means
  • Good CFM for its size
  • Well built / Sturdy
  • Quiet for its speed
  • Reliable
Average means
  • Decent CFM for its Size
  • Not very audible
  • Reliable
Terrible means
  • Bad airflow for
  • Flimsy
  • Audible
CONSISTENTLY GREAT
Coolermaster
Corsair
GPU'S
Graphic Card's
Great means
  • Quiet
  • Low temps
  • Sturdy
  • Very Overclockable
  • Reliable
Average means
  • Not very audible
  • Decent temps
  • Sturdy
  • Overclockable
  • Reliable
Terrible means
  • Very audible
  • Bad temps
  • Weak
  • Not very overclockable
  • Not very reliable
CONSISTENTLY GREAT
Asus
EVGA
Gigabyte
Sapphire
Powercolor
Zotac
HDD'S
Hard Disk Drives
Great means
  • Reliable
  • Long Lasting
Average means
  • Reliable
  • Not very long lasting
Terrible
  • Not Reliable
  • Doesn't Last Long
CONSISTENTLY GREAT
Seagate
Western Digital
MONITORS
Great means
  • Great Picture Quality
  • Reliable
  • Sturdy
Average means
  • Decent Picture Quality
  • Reliable
  • Sturdy
Terrible means
  • Bad Picture Quality
  • Not Reliable
  • Weak
CONSISTENTLY GREAT
Asus
BenQ
MOTHERBOARDS
CONSISTENTLY GREAT
Asus*
Gigabyte
PSU'S
Power Supplies
Great means
  • High Quality
  • Long Lasting
  • Reliable
  • Quiet
Average means
  • Good Quality
  • Lasts a while
  • Reliable
  • Quiet
Terrible
  • Bad Quality
  • Breaks quickly
  • Loud
  • Will catch your house on fire
CONSISTENTLY GREAT
Corsair
Seasonic
Sparkle (SPI)
XFX
OCZ
SOUND CARDS
CONSISTENTLY GREAT
Asus*
SSD'S
Solid State Drives
CONSISTENTLY GREAT
Samsung 830, 840 Pro
Kingston Hyper X 3K
Crucial M3
CONSISTENTLY GREAT
Corsair
G.Skill
Samsung
PERIPHERALS
CONSISTENTLY GREAT
Corsair
Logitech
Saitek (Madcats): Mice*, Keyboards*
Their Xonar sound cards have some software issues
http://www.tomshardware.com/forum/240332-49-asus-xonar-software-driver-problems
Their Motherboards custom software has problems
http://rog.asus.com/forum/showthread.php?22918-AISuite-won-t-install
Great products until they break, then good luck, their customer support is to be feared, and their RMA process doesn't exist.
I will periodically update this list, and remember, this is essentially a guide for new people to reference when they need to. If you have any problems with an item on the list, like it should be in a different category, don't be afraid to dispute it.
· Aint da way it used to be
I would like to point out that although ASUS has incredible hardware, their software is absolutely terrible in my experience. Particularly their sound card software. And their mobo utilities also are very buggy, and I am currently experiencing major bugs with their USB 3.0 drivers. And a quick google search shows I'm not alone.
Also, I think this thread may have good potential, but may have a bit of a chance for bias in it. For example: I have loved my OCZ power supplies. Not saying others haven't had bad experiences, but what is the criteria for "consistently bad" because for me OCZ PSU have been "Consistently Good". Just a thought.
Can anyone else confirm this?
I won't remove it from the consistently great section, but I will probably be putting star's or something in and put a list down below with known problems and hopefully links to fixes.
· Premium Member
I don't get this thread at all.
OCZ definitely aren't consistent, up until the Vertex 4 many of their drives suffered from a variety of issues.
Corsair have had major issues with their Force series SSDs, the firmware and software for their peripherals has been glitchy, their hydro coolers have had huge pump issues and their Corsair Link software has only just become usable, these are just some off the top of my head.
Seasonic I would have to agree with because the majority of their products are great.
Asus are hit and miss, their products are generally overpriced, especially their motherboards and graphics cards. They have issues with their sound cards and their AI Suite software still does not work properly. Again this is just some things I can think of, I'm sure there's more.
All companies make bad and good products, it's always better to judge individual products rather than a company as a whole. The only thing that matters to do with the company is their customer service.
I wouldn't remove from the "great" section either. I love ASUS, and will use them forever. Just see the sig rig. But an asterisk by it may be a good idea.
Heres a few sources:
Sound Card Issues
Motherboard Utilities
OCZ PSU's I have to disagree with the OP. The one that I had die on me (of many used) was RMA'd and a brand new one back at my doorstep in under 48 hours despite having to go all the way to Amsterdam, they even sent me updates at everystage of each day I waited. I would rate them for PSU's between consistently great and consistently average and challenge anyone to name a current or recent line of PSU's from them that were consistently bad.
Madcatz now they have a [email protected] RMA. My RAT 5 took 2 weeks and at no point did they aknowledge receiving it or despatching the new one. Infact a week after the RMA was all over they emailed me asking if I had sent the thing to them yet.
Seagate also have a slow and shoddy RMA process with awful customer service.
I do agree, every company has problems, but I started this thread as a sort of quick reference guide for people to look at if they need quick help.
I do agree that the Corsair SSD's arent the best, the firmware and software for the peripherals is now great, I have never heard of the Hydro series coolers have any problems, and if they do, Corsair promptly replaces them. Corsair link is just a terrible concept to begin with.
As for Asus, yes they do cost more, but rarely ever do you hear anything bad about their products. I'm not making this list for Affordability, I'm making it essentially for everything else. Reliability, Customer Service, Product Quality, etc.
And OCZ, I only put them into the great section for specifically the Vertex 4, nothing else.
Discussion Starter · #8 ·
Sound Card Issues
Thank you kindly for those links.
I personally have an OCZ PSU and my friend has one, on startup of certain games, it sounds like the electronics are being overloaded, like a buzzing noise comming from the PSU that isnt the fan. Their RMA process is alright, and to be fair, I never did have problems with the PSU, just the noise, but that noise sounds bad. I will move it to the average section.
I cant really agree with this kind of thread in general. most of the products, each company utilizes another companies technology/stock to manufacture the item. for ssds, the type of controller may vary. PSU oems will always vary and stuff like that. One should never judge by brand but by the very specific unit. Sure some brands are slightly more consistent than others, but it does not mean it is always better, and that's the catch.
Could you be more specific with this link, its kind of vauge. Its more just a google search, specific website please, I want this to be helpful, not something they can do themselves.
it might be better if you divided the catagouries ie motherboard manufactoreers harddrive manufactoreers ect
also why are they great is it reputation is it price is it aftersales service ie samsung 830 series ssd v intel 520 series ssd in the benchmarks thiese 2 models off ssd are constantly in the top 3 when it comes to benchmarks only differance between buying one from the other is price where the samsung is a lot cheaper than the intel
as far as im aware the ocz ssd are the worst on the market constantly failing after one or two years off use
Discussion Starter · #12 ·
I am sort of putting it into group, if someone else says it should be in groups I will do so.
And I did explain, if you read the whole post, and I will add the Samsung and Intel SSD's to the list.
· Premium Member
While Asus has a lot of good stuff not everything with a Asus label is great or even good. Like the above mentioned lackluster software for motherboards or slightly dodgy build quality on low end laptops. Nor are all Corsair PSU great as the CX line is average at best.
No matter what way you slice it almost all big companies make some products that are sub-par.
Discussion Starter · #14 ·
Hence the reason for the Astericks
LINK
Heres a specific one. I just did a google search to show that it is a pretty universal problem. As a side note. I was eventually able to get it installed, After tons of headache, but it is real buggy. Messes with my fans, opens itself sometimes, sometimes not, shows in the taskbar when its not open (sometimes), in fact thinking about it I may just uninstall it.
Discussion Starter · #17 ·
Originally Posted by ironsurvivor View Post
Crucial SSD? Should that be in consistently great?
It is now
1 - 17 of 17 Posts
