If cost were not to be a factor, buy a full tower and get 4 9800GX2s on a 4 pcie mobo of your choice. A few dummy plugs and you will be pumping out some srs ppd
Originally Posted by nafljhy ![]() i7 has 4 cores but because of hyperthreading, it can go up to 8 threads. iirc. i could be wrong though. |
Originally Posted by Millillion ![]() You are right, though you probably wouldn't get twice the PPD, because In hyperthreaded processors only part of the core is copied,not the actual execution cores. Intel says hyperthreading gives about 15-30% more performance, but I don't know how much that would be for [email protected] |
