1 - 20 of 26 Posts
Looking to build a computer for my uncle. He wants a silent computer case. What computer cases do you recommend? Money is not a real big issue. I would say that I wouldn't spend anything more than $300 on a case.
I already have a P183. I'm not sure how my well my computer case competes with other computer cases. I would be willing to swap my P183 and buy myself another case. One computer case I'm eying right now to switch with is the Corsair Obsidian 800D. How silent does the 800D perform against the P183?
Remember, a quiet computer is a whole ecosystem of parts, not just a "silent case." Yes, the Fractal Design R3 is a nice choice for a quiet system, put a pair of stock GTX 580 in SLI plus a 2500RPM 120mm fan to cool the CPU and you'll have a noisy system.
The P183 and R3 are both decent choices to get you started. What other parts are you using?
Where can I buy the fractal design r3 in usa, the ones at newegg all out of stock.
I try but they don't have it. Only in ncix canada
Sent from my VM670 using Tapatalk
I'm using a Fractal Design R3 in one of my builds right now. In fact, it is the one in my sig.
But it's not as silent as I expected it to be. The only fans I have installed are the two front intakes (fractal design fans that come with the purchase of the case) and the two corsair fans that are on the H70. All of the other modular ventilation holes are still blocked up with the sound dampening material. I can tell you that it isn't completely silent.. it really depends on what your expectations for silent is.
But regardless, this case is still pretty sweet. Perhaps go with a Noctua cooler since the corsair fans are known to be loud anyway.
· Solar Junkie
Heya,
I use the http://www.amazon.com/Whisper-Black-Power-Aluminum-Computer/dp/B001H9ALF2/ref=sr_1_1?ie=UTF8&qid=1319042767&sr=8-1]NZXT Whisper.[/URL] It's an enormous, heavy, steel case. It's got internal dampening material. It has a ton of room for air or water components for cooling and ports to run things around in/out of the case. It has great cable management inside (ports and holes with flashing to keep it tight). It also has a ******ed amount of removable HDD storage (9 of them). It's a bottom mount PSU design. It's dead silent. Plus it's classy looking, not flashy and ugly like some "computer" design, it just looks like a dark brushed monolith.
Very best,
Yeah the Fractal Design R3 looks pretty good but only NCIX and Newegg has it, but in newegg is out of stock and the R3 has it only in ncix canada. I like that the NZXT looks simple and has the ability for water cooling because also I've been thinking in buying a water cooling kit.
· Premium Member
I don't know if it is the "most" silent but the Sonata III 500 is a great case if you are trying to build a quiet computer. I have done probably five or six builds for customers with that case.
Agreed about the ecosystem point.
For example the Silverstone Sugo 07 shoebox-styled case doesn't seem like it'd be quiet. But equip it with a fanless Sapphire Ultimate card, Noctua NH D9B SE2, and you can apparently get a pretty silent system and its stock PSU is relatively quiet as well. The case (includes high quality PSU), cooler, and video card would run you about ~$400 before taxes, probably less. The following link was able to get sound levels ranging from ~16db to 22db, depending on the fan speed/sound setting, also has decent cooling too:
http://www.kitguru.net/components/cooling/zardon/noctua-nh-u9b-cooler-se-2-with-silverstone-sugo-sg07/9/
Ya how quiet do you want / need?
A whisper in the corner, I like the Fractal design 3 with 4 120mm 800RPM fans. Gives enough cooling for everything but high end GPU's (for quiet).
If you want dead silent either have to have less performance parts or go full water.
Quiet that don't disturbe anyone
Sent from my LG-P999 using Tapatalk
· Linux Lobbyist
Sound dampened Antec Mini P180 with no window, IMO.
Also, a properly dampened Lian-Li PC-A05 would do pretty well
The antec wins pretty hard though, you can dampen the front of the by putting 1/8th sound dampening foam inside the front panel, then you can further dampen it by putting foam on the inside of the front panel, and again between the front panel and the case, you can fit 1" cone foam on the whole left panel of the case, and the top panel, as well as the first bit of the right panel, and the majority of the rear panel and floor can also have 1" cones. couple that with filling the drive bays with foam blocks, and you can have a nearly dead silent build. Even more silent with low rpm fans on low fpi radiators.
I have the NZXT H2 as well and with the fan on my 212+ turned down to about 75% it's almost inaudible above other sounds like my typing or even chair moving around. Plus it has excellent airflow and a few nice features like the SATA harddrive bay on top. I really recommend it!
1 - 20 of 26 Posts
