Hi there,
I'm planning a build with the following:
- AMD Phenom II X2 555 (planning to unlock cores, then OC after stabilizing)
- G.SKILL 4GB (2x2GB) DDR3 1600
- POWERCOLOR AX4850 512MD3-PH Radeon HD 4850 512MB
- Standard HD, DVD, and ATX Mid Tower etc...
- Will upgrade cpu fan to Sunbeam CR-CCTF
I'm leaning towards either the Asus M4A785TD-V or the ASRock M3A785GMH.
Which do you think is the better option? Or, I would welcome any recommendations other than the two I've listed.
Many thanks in advance.
