so i just bought this combo package from newegg
came with
GIGABYTE GA-MA770T-UD3P AM3
http://www.newegg.com/Product/Produc...82E16813128392
AMD Phenom II X2 550 Black Edition
http://www.newegg.com/Product/Produc...82E16819103680
i went back and looked and the specs more and noticed that on the motherboard is only supports phenom x3 and x4
will an x2 run on it?
and if it does can you suggest a budget heatsink for this am3
thanks in advance
came with
thanks in advance
