1 - 6 of 6 Posts
Originally Posted by metalkobra
I wouldnt worry about it too much, i mean it works right? perhaps the hs is too heavy, but im sure its fine.
Yep, I'm using it right now!!! But i have to say this... "I HATE THAT HSF"
So is there anyone else who has a mobo little out of shaped like that?
I'm a little worried
Are you using all the stand-offs? If so the board is getting all the support it needs, and a little flex is nothing to worry about. If your not using all the stand-offs then I would get them in.
id worry more about the pci slots being different lengths. (attempt at a joke) anyway my gpu is warped slightly, it freaks me out a bit but i think it is relatively normal. over time pcb can be stressed and retain a different shape than intended.
1 - 6 of 6 Posts
