Motherboard Monitor
778 4
I just downloaded Motherboard Monitor and all 3 senors say 0C. Do you guys know what's wrong?
1 - 5 of 5 Posts
What do you mean all three sensors say zero? (screenie?)
Right now I have 15 sensors activated right now and 6 of them are reading zero because I dont' use them.
EDIT: Type what sensors say that.
You need to open the MBM control panel (right click on the icon) and in the first tab select system info.
This will give you all the sensors that MBM sees in your system. With that info, change the appropiate sensors accordingly. After that you should have no zeros.
motherboard monitor has been dead since july 04... so youll have to pick a mobo/ sensor from the list thats as close to yours as possible or find a 3rd party tool
Correct... development has died!
1 - 5 of 5 Posts
