1 - 17 of 17 Posts
Aye im waiting on my case to arrive tomoz and i was just testing my mobo on its box with the cpu installed and the RAM and a video card and i power it up all the fans spin but no bios beep or no display signal, i tried the onboard video same thingwhat could this be? I will upload some pics soon.
· Premium Member
Given that you know everything is compatible:
Clear CMOS and try again.
If still no beep or display %90 of the time it's the PSU (%100 if it's that 400W Superflower in your sig). Regardless of the brand, watts, or how new your PSU is, plug the system up with another good PSU and see if it boots.
· Premium Member
· Not new to Overclock.net
Discussion Starter · #9 ·
Oh. That's why it isn't functioning properly.
· Premium Member
Originally Posted by Gawdz
I cant exactly run this software because my mobo wont boot.
If you have spare TIM laying around, just pop off the CPU cooler and read what is printed on the CPU IHS lid. Model # should be right there.
If it ain't on the support list, then you don't even need to bother remounting, as it won't work with that motherboard.
Well I guess finding out which one it is doesn't matter anymore because now we know that the culprit is that the mobo doesn't support any Pentium D processor.
TIM? well doesn't look like my Celeron D is supported either so is it possible for that update to work if not....
IM IN NEED OF A CHEAP CPU!
What about that E8400 you were lookin' at?
1 - 17 of 17 Posts
