1 - 6 of 6 Posts
I'm running my computer caseless at the moment and have lost a lot of the risers / screws for my Antec 300. Does anyone know where I can get some more that will 100% work? I was using some before but they're a PITA to get out because the threads don't line up properly.
Thanks.
I have used threads from 3 diff comps in mine. Ideally they should all be the same if they arent like 20 years old. The height might differ but the thread should be the same
Yea my previous build I only used 5. 4 corners and a middle for hsf support.
1 - 6 of 6 Posts
