I'm using an adapter with a 900 MHz Processor in one of my rigs, so no... As long as the adapter is rated for that speed it should be fine.
Originally Posted by Bdog I couldn't get a p3 1Ghz 133bus to work. I would think a p3 1Ghz 100bus would work. |
Originally Posted by Ropey ^^ Correct ^^ One can not exceed the maxium of the board. If the board is 100MHz fsb maximum then the converter will only work at the rated board maximum. If you overclock via the board you will get the overclock maximum with the concurrent raise of agp/pci bus as well. R |
