1 - 4 of 4 Posts
i got some ram for a gaming rig then realized it wouldn't work with it before even terning it on.. the moutherbourd takes 800mhz max and i mistakenly got 4GB of crosshair 1000mhz RAM
can anyone suggest a under $150 moutherbourd to put it on?
Car cheaper than computer
You can run 1000Mhz ram in a 8oo Mhz ram board, if ram fits it should work (Within reason)
lookat my ram, it is running with PC 5300 speed if I was at 200 mhz fsb, point made.
Rule of thumb: Aussies need to pirate to get good games, so justify it as protest of the the rating system there.
1 - 4 of 4 Posts
