motherbourd voltge
332 Views 5 Replies 3 Participants Last post by  CattleRustler
im doing a little moding with LED's anyone know the voltages coming from the OFF/ON switch pin's , HDD led pins , Power LED pins
i don't have the tools to check voltages*
1 - 6 of 6 Posts
Give me a second, and I can probably get a reading for you.
Power display, and HDD activity pins should be around 3V, as they run LED's on their own.
Crap... Too dark in there, I can't get a reading.
Sorry man. I'd guess it would be 3.3V, that would make sense to me.
Edit: one of the prongs just fell off my multimeter. May have been the reason I couldn't get a reading...
aww damn D: can u fix it? and the led's i looked at on ebay are 3.5v
I have a packet from DSE in front of me that says 3.2V operating range.
The ones in my DVD drive are setup to draw 3.2V
Note: LED's should work above 2.2V. A lot will burn out going above 3.5V though. Blue ones are usually rated higher, as they use more energy
These are the ones in front of me: http://www.dse.com.au/cgi-bin/dse.st...uct/View/Z3009
Also, read this: http://forums.bit-tech.net/showthread.php?t=145317
power led and hdd led pins are usually 3.3v
1 - 6 of 6 Posts
