1 - 4 of 4 Posts
I'm thinking of venturing into the world of Mountain Mods for my next build. I was playing around with the CYO flash builder on their website and I think I found a design that I like. My plan is to put 6 intake fans on the front, either CM R4's or Xigmatek XLF-1253's. Then I want to have an RX360 with Gentle Typhoons from the group buy in push exhausting out the case. I know the horizontal mobo support bar will interfere with the side radiators, so I plan on either modding it, or building some other means of supporting the mobo tray. My only other concern is that there won't be enough room in the corners and the radiators might not fit. The radiator plus fans and gaskets is about 90mm thick. If anyone have any insight on the matter, it would be greatly appreciated.
Back to Building
Anyone else? I also emailed MM the same question, but have not heard anything back yet
Sent from my Nexus One using Tapatalk
1 - 4 of 4 Posts
