1 - 20 of 21 Posts
Is it okay to mount a hard drive label side down? I have a WD 1TB Green drive and was wondering if it was okay to mount it in my case upside down? +rep for help. Thanks!
Yes you can because some time ago I did just that and there was no ill effects...go for it.
It's absolutely fine, I have done so for extended periods of time with no ill effects. Any direction you want to mount it (even on 1 corner) will be fine as long as it is supported properly
Reactions: special1zed
Originally Posted by dralb View Post
Yeah, it'll be OK. Can I ask why you need to mount it upside down?
screwing it down to the top of the chassis perhaps?
also I've got an external enclosure that's got it upside down as well.
in any case, you're fine. I've had my external HD mounted belly up for the past year thereabouts.
There is no such thing as "right side up" for a hard drive, therefore they don't know if they are upside down or not!
Think about desktops vs. towers, servers in racks, etc. Modern drives can be mounted in any orientation (but this was not always the case!)
..a
Theres no problem with mounting it upside down had an old case that had an extra rack for hdds that once you mounted the hdds and inserted the cage had all 4 hdds facing straight up. Way its mounted doesnt matter just as long as its secure and not just swing from the molex
I have mine mounted on their edge on the bottom of my case with a 1" gap between them to keep them cool. I have a 120mm intake 1" in front of them and I have never seen them more than 2* above ambient.
I asked this same question here almost a year ago...everybody said its fine..nothing wrong...etc..etc...
but it killd my drive ... don't do it..
This made me thinking. I suppose there's some hard drives in the ISS and spacecrafts, probably SSDs now though. But in "the old days" (which is before SSDs
), they must have used a hard drive. If a hard drive works in outer space, I suppose it'll be able to run upside down.
Being upside down did not kill your disk - something else did, or it just failed.
Gravity is insignificant compared to all the other forces acting in an operating HDD. Any direction is fine - just make sure it is securely mounted and not subjected to any shocks while running.
just think of it like this, do you know which way is up on a external hdd when you sit it down?? not on the element drives you dont. So yes its perfectly ok
I remember Syrillian talked to WD about mounting them at odd angles for his Silentium build. They said it didn't matter as long as the HDs were not being moved around.
1 - 20 of 21 Posts
