Hi,
I would like to mount 2 sets of 2 cathode inverters in my case, but just the PCBs not the inverter box. The boards come right out of the little case when it's opened, but if they were say, hot glued to the bottom part of the inverter box, that would be better than trying to mount the PCB directly onto the (metal) case wall I would think. Hot glue and silicone adhesive are both insulators, afaik, so one of those should be OK, yes?
