Why? mounted hdds upside down before then put them the right way up and sometimes on their side no problems as long as it done when turned offOriginally Posted by dave12;14211014
It is fine but you will have to mount it upside down again if you ever move it.
Did you just make that up?Originally Posted by dave12;14211014
He did.Originally Posted by D311;14211134
Hope he did make it up heh. These were rightside up now upside down
Originally Posted by ryanbob1234 ![]() Why? mounted hdds upside down before then put them the right way up and sometimes on their side no problems as long as it done when turned off ![]() |
100% of my WD drives mounted upside down have died. (3/3)Originally Posted by Willhemmens;14211206
He didn't make it up. Older hard drives could only be mounted in one orientation due to the read/write head changing position slightly when moved. Luckily this will not be an issue with modern drives.
