1 - 7 of 7 Posts
Just got the new board and proccessor (skt 939 athlon 64 3000+) and a slight problem the hsf mounting bracket thingy isn't on the board(but not missing) and just wondered if there was supposed to be a backplate for the retention bracket? Also what screws to us
Elitegroup K8T890-A mobo
AMD Athlon 64 3000+ proccessor
Cant wait to get this fitted
Im not quite sure I understand what your talking about but do you mean the black plastic bracket? That screws into the mobo around the processor. Does this help at all?
Best I could find on google.
If your eliminating the "Top" part, the bottom, if I recall correctly, uses 6-32 screws.
Yes, You need to have the metal backing plate on it...I'm sorry I dont have any links to one....If I can find one I will link you...
1 - 7 of 7 Posts
