Quote:Originally Posted by fat_italian_stallion;13105591
you can mount them sideways no problem
Thanks this is helpful my plan is to put it between to sponges and stuff in towards the front of the case in a 2x 5.25 bay slot. I think it will hold really snug right there and be completely hidden I don't have much other options as well unless I ditch one of my optical drives.Originally Posted by gre0481;13105633
As long as your seals are good (O ring) it should not matter how it is mounted. A seals a seal. However depending where you mount it could effect the acoustic sound levels. It might be louder if say you mounted it to a flimsy side panel instead of a sturdy frame to a case. Water provides more stability than air. It's not like mounting a HDD at a 45 degree angle.
If you look at it while unscrewing the the knobbed ring that holds the pump to the top, you could turn it in a complete circle and see no difference, other than the inlet/outlet in the pump top. You could put a bracket in any direction, and still get the same performance. (if the mounting holes weren't in a specific location)
ThanksOriginally Posted by Rangerscott;13107079
Pulled out my instrustions and it said you can mount it any way but upside down.
Thanks rep to allOriginally Posted by LiNERROR;13107145
same pump, different housing, do not mount where the bearing is above the rotor
