I'm having some issues mounting several fans to a few Black Ice Nemesis GTS 480 Radiators. There are two sets of screws that came with the Radiator on order a long and short set. I've been working on mounting the cooling fans to the radiator. Some the screws i can tighten the fans to the Radiator, on the other holes the screw won't tighten at all and just seem to keep spinning and not tightening at all into radiator holes. So on mounting one fan i might get two holes to tighten and the other screws both loose. How do i fix this? Do i need to get a different set of screws or bigger screws?
Also when i also try to mount the Radiator to the top of my CaseLabs Case the short screws that came with the radiator are too to allow mounting to the top of the case. I couldn't get a single screw to thread at all. Anyone know what size these screws are. I'm figuring i'm going to have to spend some time at Home Depot or Lowes to hunt for correct size screws.
