1 - 5 of 5 Posts
Hey guys,
Sorry if this has been discussed/answered extensively in a heap of other threads (if so, could you please link me to it/them).
Does mouse pad material & thickness effect mouse sensor accuracy & responsiveness?
Thanks!
thickness not really. material yes.
some materials that reflect a lot of light tend to not work well with most sensors. kinda vague but I hope you get the idea
depends on the sensor and how well it works with different materials.
distance from sensor to mousepad matters a bit, so mouse feet thickness will make a difference, but not mousepad thickness.
best is not-so-reflective all black surfaces with some texture.
No, you should be A-ok. The 3366 isn't picky with surfaces. You could probably track well on a bed of nails with the 3366.
In other words, don't worry, you are fine with whatever pad you choose/prefer.
1 - 5 of 5 Posts
