1 - 16 of 16 Posts
Hey, I have recently got a second monitor, and as a result have had to move my case off the desk and onto the floor (Carpet) Just wondering if this is a bad idea, and if i is should try and find another way to put my case?
The case is the one in my Sig.
· Questionnaire galore!
Put something below it, to remove the static made by the carpet
It has Rubber feet i am fair sure? Should I still Put something such? Plank of Wood?
The case has rubber feet so the OP won't have to worry about static electricity. He needs to worry about dust more.
Yeah..
Why Exactly?
Cause of the static it makes..
· Older "geezer" of OCN
The dust, possible static and the case/fans on the bottom not breathing.
Here's what I've done with my case on the carpet:
Wood from a former desk I found on the curb but you can use any plywood of soughts or find such furniture on the curb and use a piece.
Also what i did to mine..
My room is so dang dusty..
Reactions: ObscureVisions
1 - 16 of 16 Posts
