Moved my rig, now my connection sucks :(
347 Views 9 Replies 5 Participants Last post by  Koolade
Yea so, I moved my main rig about 15 feet from the main open part of my basement, into my room, and now my wireless connection is horrible.
My router is on the floor above me in the middle of the house, and I'm in the basement in a corner of the house under the kitchen. The best ping I've been able to get so far is 560ms.
I'm using a linksys WUSB54GS and our router is a home router of some kind, too lazy to go check.
I have been moving my wireless usb device around a bit, moving the antenna and it seems to be very.. picky. I'll move it an inch, and it will go from 600ms to 2500ms..
So I'm looking for suggestions on how to improve my connection. My laptop is in the same room with it's built in wireless and it atleast gets a "low" connection as opposed to a "poor" which my main rig gets.
I've considered a wireless extender or something, but I haven't heard if those really work. And I wouldn't know where to put it anyway.
Help is appreciated and repped
1 - 10 of 10 Posts
drill thru floor and run cat5 cable wired is better and can be hidden well
I'd be looking at getting a better antenna, one of my friends had this problem and the antenna was the cause of the dropouts/very bad pings.
Might help to buy a router with a stronger range. I personally use dual usb adapters though, seems to work pretty well. You could also consider hardwiring if it's not too implausible.
Id suggest a antenna also, new egg might have some good black friday deals on one.
An antenna for the router?
I've been trying to upgrade our router to Wireless-N (trying to get the parents to take care of the financial part).
If I had the skill and know-how to run a cable down here, believe me I would. I used to run off of a wired connection and my gosh it was beautiful. I don't think it helps that there are 5+ computers on my network, not including the Xbox, PS3 etc.
I guess if I had a 100 foot cable, I could find someway to drop it down here.. my poor parents.. they have to put up with me too much.
They don't conflict?
Also, I'm wondering how to position my USB receiver thing for the best possible connection. How to aim the antenna, put it up higher? etc etc
Raised my receiver as high up as I could and now it is better, but still not great >
1 - 10 of 10 Posts
