Well it depends. Try to get you CPU stable at 4.0Ghz and see how m0ch voltage you need. Even if you reach 80C under load you should be fine for a bit. True should be a good 10C cooler.
Originally Posted by jclark ![]() As I'm quiet disappointed from the O/C level I've managed to get from the Zalman CNPS 9900 I'm thinking of moving to a TRUE and would like to know if it's really worth it. Some facts first: 1. I've managed to get my i7 920 to 3.8 @ 1.24 and max temp of 71c. 2. I'm not going to lap it as I don't have the time/patience and we don't have Megahalem's here in Israel. 3. I'm not going to Push/Pull as 1c-3c difference seems pointless versus the noise gain. 4. I'm going to use this fan since it has speed control: http://www.thermaltakeusa.com/Produc...4&ID=1726#Tab1 Now taking these factors into consideration I would like a few answers if someone could be kind enough: 1. Will I be able to keep it under 70c with O/C around 4-4.2 and ambient temps that can reach 32-34c during summer. 2. Will that fan do the job? 3. Is it really worth the hassle or should I be happy with the final O/C results of the Zalman CNPS 9900? |
