I wouldn't try it tbh, it should be fine but at work when working with raids there you can't move the drives or you'll mess the array up. It could be different with desktop arrays though. When you set up your new OS, take the array out then put it in after install, you'll probably need to install raid drivers but it'll just see the drives as a single volume.
