1 - 4 of 4 Posts
The best way to ensure that they all sound the same is to make sure they are all downloaded at the same bitrate.
I don't think there's any way to do that with Mpeg Layer-3 encoded audio without losing quality. Try using GoldWave. Open all the files you want burned, find the one with the lowest volume RMS, and then adjust the RMS peak on all the tracks to the lowest value.
1 - 4 of 4 Posts
