Mp3tag
2853 Views 1 Reply 2 Participants Last post by  soadrocksever
Program Category: System Utilities
Mp3tag is a powerful and yet easy-to-use tool to edit metadata of common audio formats where it supports ID3v1, ID3v2.3, ID3v2.4, iTunes MP4, WMA, Vorbis Comments and APE Tags.
It can rename files based on the tag information, replace characters or words in tags and filenames, import/export tag information, create playlists and more.
Mp3tag supports online database lookups from, e.g., Amazon, discogs, or freedb, allowing you to automatically gather proper tags and cover art for your music library.
Version 2.45a
Publisher: http://www.mp3tag.de/en/
Download: http://www.mp3tag.de/en/download.html
1 - 2 of 2 Posts
LOVE this program!
tips, uses standard key-combos to move around, i.e. in one field, tab will move right a field, and shift tab will move left a field.
Enter will go down, shift enter will go up.
Also batch replacement of files are easy, select all the ones you want, and then on the left pane, edit, then hit the save button at the top(that confused me when i had first found it)
The shortcuts at the top to auto rename groups of mp3's file names based on parameters such as song name/ track/ artist/ album to your liking.
highly recommend this program!
1 - 2 of 2 Posts
