1 - 3 of 3 Posts
Which would be better; buying a really good 478, or buy a OKish 775 and upgrade later??<br />
<br />
my budget is about $150, and i already have a CeleronD 330 (2.6ghz)
There are two types of Celeron D: <a href="http://processorfinder.intel.com/List.aspx?ProcFam=1756&sSpec=&OrdCode=" target="_blank">http://processorfinder.intel.com/Lis...Spec=&OrdCode=</a><br />
<br />
Which one do you have? <br />
<br />
But in any case, the P4P800 is the one for the S478 and DS3 for LGA.
Hello,<br />
<br />
It really depends upon availability of mPGA478 hardware and at what cost.<br />
<br />
LGA775 socket is much newer and is still currently supported. <br />
<br />
Ive had many mPGA478 based systems over the years so if you need some pointers I can help <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 3 of 3 Posts
