MSConfig is a powerful tool that allows you to enable/disable the programs that start when Windows boots up.MSConfig would be a perfect startup manager, if it allowed you not only to disable items, but to delete them forever. Unfortunately it does not do that.This is where MSConfig Cleanup comes in! It scans the startup configurations and allows you to remove any item that has been previously disabled via MSConfig.
Try it. It's Free!
http://www.bestvistadownloads.com/so...-vtohhcgp.html
Try it. It's Free!
