1 - 1 of 1 Posts
evenin guy's
had an msi gf615m-p33-am3 mobo sat brand new in it's box for a while now. so finally decided to try and put it to use and make a cheapish htpc.
now got a lot of the stuff but not the memory - but earlier found some going fairly cheap. so looked it up and it was 1.5v per the mobo specs, but later checked and found i had gotten the higher rated memory @ 1.65v.
so my question is this, does anyone know what the max dimm voltage is on said board? because i haven't found an answer and all msi tell you is the standard 1.5v and not a range.
1 - 1 of 1 Posts
