MSI GTX 1660 Super Gaming X
1104 5
Product Organism Font Screenshot Insect
Product Rectangle Font Software Screenshot
I set a UL record tonight, lol. Core +150, memory +600. Nice card.
It looked as though this was about the best option for matching up to a 7700K at 1080p without bottlenecking either way. There was also the 3050, but I couldn't get past it being gimped at x8, and this is just a spare midrange build mostly put together with parts left over from the ADL upgrades.
Edit: 1,000th post, woohoo...
1 - 6 of 6 Posts
What does it get for a timespy regular score at 1080p?
Rectangle Screenshot Font Software Operating system
I had to roll the core back to +140, +150 crashed on me twice in a row.
NVIDIA GeForce GTX 1660 SUPER video card benchmark result - Intel Core i7-7700K Processor,MSI Z270 GAMING M5 (MS-7A78) (3dmark.com)
Here is a validated 1440p result, for comparison:
This one I think I had the core at +125.
Ok. Not much farther behind 3060ti. I get 11600 on timespy regular with whatever settings the program is defaulted to. Card is also running stock speeds on core and mem.
edit I see some 3060ti getting 12000-12300 wonder if timespy easier to run a year ago? Ha maybe mine is poorer silicon.
Strangest, most unexpected thing was the USB-C device that showed up in the device tree and needed a separate driver. Still trying to figure out what it's for -- I saw one Reddit post after some googling that stated you could connect a monitor to such a port on your motherboard if one was available, and there is one on this motherboard (MSI Z270 M5 Gaming), but probably something I'll never use. Just weird, though.
You need to check the second link. Your score for a 3060 ti is well within the norm.
Reactions: tubs2x4
1 - 6 of 6 Posts
