Just received this AIO cooler and of the 3 , 360 mm AIO's I've tried , I think it's the best of the bunch.
Price - $119 on amazon...... much cheaper than they other 2 I've tried
Stirrup style cooling block mount that appears to work for AM2 - AM3+ AMD motherboards without having to remove motherboard from case or install custom backplate. Compatible Socket & CPU: Intel LGA1150/1151/1155/1156/1200, LGA1366, LGA2011, LGA2011-3, LGA2066 / AMD AM4, FM2+, FM2, FM1, AM3+, AM3, AM2+, AM2
Quietest fans of the 3.
Great cooling ability at very low noise levels - can't hear the pump . 72 F room temp FX 9590 running all core at 5 ghz on CHV-Z 1.5volts 130% current limit LLC very high , cpu/nb at 1.435 v LLC high cinebench R20 - 52.9 C max temp , 47.9 average temp 1701 multi-thread score.
Clockable RGB cover on cooling block
Longer hoses than the others .
If you are looking for a 360 MM AIO - give it a look
