Hello,
I know I am late to the party but I just build a 5600x msi x570 tomahawk, meshify C and a EVGA 1070 acx 3.0 build and had some issues.
I run the wraith prism and latest bios driver (beta 7C84v151).
gSync activated with a Dell S3220DGF.
After installing I played a bit with some settings in the bios but nothing too fancy.
First, the cpu fan was going crazy idle, for whatever reason (NOISYYY). Then in warzone after 35 minutes screen started to act strange and finally WZ crashed (no message).
I checked the CPU temp and it was 85C at the time with our nice wraith at 100% all the time.
Idle 56 fan between 20 and 90%
I figured I could use this solution:
https://www.reddit.com/r/Amd/comments/jpfsv3
As soon as I did, my W10 was dead. Kept booting with different errors until NTFS FILE ERROR stayed.
So for me, and the build, it's a no-go.
I restored the bios default (all values, which out back the vcore and freq auto), put back my backup image, tried again WZ. Much better ! gSync deactivated (so probably running a 60hz), but it was stable, around 68C.
The Dragon software let you control the CM, check fans and temps.
I managed to activate the CM controls from the soft (it's not by default), change the profile to silent.
Cpu fan at 10 15% idle, 50% in WZ, 75C stable, which is within the normal temps if we believe AMD engineers.
I hope it helps people who might have issues with their 5600X
