3361 - 3380 of 3429 Posts
Anyone got any problems with newest bios and power limit? Doesn't seem to work at the moment for me, it just speedruns to 250W draw in cinebench xD
No problems here... As always try a Clear CMOS and don't load any profiles but type the configs instead.
Got a huge problem. On previous beta was able to push kit of F4-3466C16Q-64GTZR (I used only two sticks) to 3800/CL16 flat with decent secondary timings, but on 7C35vAA they won't boot other than XMP settings. Other kit F4-3600C16D-32GTZNC boots on 3800/CL16 just fine but voltage and timings are not that pretty
Read Only
Any of you guys compared X570 Unify and B550 Unify-X? Is it worth to switch from X570 Unify to B550 Unify-X for memory overclocking, and FCLK overclocking? Currently hard stuck at 1900FCLK on 5950X with X570 Unify.
Might as well wait for the upgraded unify 570 if you're thinking about changing for that, and see if it's any better
Anyone tested new bios for (1.2.0.3B)?? What is the best current bios with SAM enabled and proper IOMMU groupings for VM?
Weird.Found A.91 cured usb problem.Thought A.42 was best for mem overclocking on 3 series Zen(3950X.)
Struggled to do CR1 15,16,16,16 at 3800 on bios A.91 on 1.46v
Now on A.92 doing CR1 15,16,16,16 on 1.42v
Will obv check further but thats a big drop in voltage
Smiffy
Smiffy
A.92...is it 1.2.0.3A or B?
What is XOC?
Confused...A.92 4 sticks of Patriot 4400.Run perfect on CR1,15,15,15,15 on bios setting of 1.40v which bios says is 1.424v.Nothing else changed apart from bank swap disabled and bank swap alt enabled.Try CR1 15,14,15,15 and lots of memtest5 errors.So reset to 15,15,15,15 and still loads of errors,Reflash A.92 again and errors gone at CR1,15,15,15,15.Try 15,14,15,15 again and errors back.any ideas?
2520436
Fun FACT It seems mainly focussed on Cezanne APUs and they rolled back the SMU for Vermeer from 56.53 to 56.52. I wonder why.
Asus has not downgraded the SMU for Vermeer...
2520456
Seems like another sloppy MSI job preaching to be first. The interns at it again.
I think msi on certain division are joke like bios team bunch of trolls ill never buy msi board again asus is honestly best in bios
So goddamn weird, it still doesn't want to work if I flash an UBU updated BIOS... Are you guys using the modded 5.2.0.24 mmtool? I changed to that now but won't try yeeeet again until there's a new version xD
@Eder
Any particular reason you have not unhidden "CPU vDDP" ??
That was very useful on your previous BIOS in allowing my 4133/2067 profile to post almost 100% of the time.
All I had to do was set it 20 mv less than "CLDO vDDP".
Without this I get about a 25% failure to post scenario (Error code 07)
Reactions: Mach3.2
