Im oc'ing this thing finally and need some help understanding a few things. Im using Afterburner for oc.
1) whenever the card is under load the voltage jumps up to 1.25v ilo 0.95v (stock). no matter what the setting is at, it goes up to 1.25. im assuming this is a boost function and the value set is a min?
2) what is the max voltage and approx max oc i can expect from this thing?
3) what is the best way to test stability besides the obvious? kombuster GF OC Test (GL4)?
have this guy http://www.newegg.com/Product/Produc...82E16814127667
ive pushed it up to 1000/1275 @ 1.005v and have issues with bsod's and freezes (stock is 960/1250). all sensors in different programs are all over the place, confused?
thnaks
thnaks
