1 - 13 of 13 Posts
I have a msi z590 a pro also my psu is a evga 750 g2, i only have one gtx 960, a inland premium 1TB m.2 ssd.
My psu has 2 x 8 cpu power.
4 x 8 gpu power.
What can i do yo add power to the pcie power plug on my mobo?
Discussion Starter · #2 ·
I've got two of these. It says 6 pin power but on both, a pin is missing. 20210617_130833.jpg 20210617_130851.jpg
9 Cans of Ravioli
RTFM
you don't need it with a single GPU.
RTFM
That's what I just found out from MSI's 800 number.
It's if I was running like a GTX 3080 or 90 whatever it's out now two of them.
RTFM
I cannot find anything saying it saying for more than one GPU in the manual.
See attachment.
9 Cans of Ravioli
because you don't need it for >1 GPU, either. it's for fringe cases like mining or HWBOT where you're worried about overloading the 24-pin.
You said rtfm. Aint that mean read the f++king manual? 😕 🤔
9 Cans of Ravioli
you can swap it with LMGTFY if that's more fitting.
Discussion Starter · #9 ·
You said RTFM so i went through it throughly, the manual has no information "mining, hwbot nor anything else for that matter" about pcie pwr1.
∆ that was the point i was making ∆
9 Cans of Ravioli
I wouldn't have said "swap it for LMGTFY" if I wasn't aware of your point, no?
Discussion Starter · #11 ·
My motherboard didn't even come with a manual I had to download the PDF Is this something new with motherboard manufacturers?
Robotic Chemist
Not very new, most devices are going digital distribution for manuals. Most people don't read them or lose them before wanting to reference them anyway. :p
I like the digital manuals, I use a tablet to reference them while building.
That board's 2nd x16 sized slot is an x4 from the chipset anyway so you wouldn't want to run a gpu in that 2nd slot.
2x PCIe x16 slots
Support x16/ x4
PCI_E1 (from CPU)
Supports up to PCIe 4.0 for 11th Gen Intel® CPU
Supports up to PCIe 3.0 for 10th Gen Intel® CPU
PCI_E3 (from Z590 chipset)
2x PCIe 3.0 x1 slots (from Z590 chipset)
1 - 13 of 13 Posts
