1 - 20 of 30 Posts
Installing this update on Windows 7 X64 Will cause Folder Renaming Problems.
This exactly what happens.
If I try to rename any folder in my system, I get "Could not find this item" with the choices "Try Again" and "Cancel". When I click "Try Again", it always succeeds. So - my system isn't crippled - but it is so totally annoying. I can even right-click on my desktop, and choose "New... Folder" and type in a name, and I get "Could not find this item". The interesting thing is that the item's name does change even before I click "Try Again".
If I have a folder named "Folder1" and I rename it to "Folder2", I get the error that "Folder1" Could not be found - which is actually true, as it is already renamed to "Folder2".
I ended up reinstalling my OS.
Problem solved, then I updated But before updating I created a system restore point.
Boom my problem recurred again.
So I uninstalled ALL updates. Rebooted. Did a system restore point that I created. Boom Problem gone.
So I googled New MS Update.
I came across this link here.
http://www.dslreports.com/forum/r241...-today-4272010
Hit CTRL + f, typed in rename, took me down to a description [KB980408] "7th post down".
I read it, instantly knew it was that one update.
So I am still at my restore system point, decide to install all updates except this new one"KB980408".
No problems + my system started up a alot faster with out it!
Be cautious and create a system restore point before installing MS Update.
I hope I may get the word out before this happens to another person, it will save a lot of time.
that is why you leave updates turned off...
(install SPs after they are tested for a good month)
Super Moderator
Weird, I don't have that problem, and I rebooted this morning to install that exact update.
VeeDub Enthusiast
installed, none of the stated issues known.
I have that update, and have no issues with renaming any folders.
I haven't had Windows updates turned on in the longest time. I used to have BSoDs from bad updates every so often on Vista, and I'm not taking that chance with Windows 7.
I got all the updates also and no problems renaming or making folders on the desktop.
The thing is updates don't affect everyone the same way. As I sad in my earlier post, I used to get BSoDs from certain updates under Vista, but obviously not everyone had the same crashes from the same updates as I did.
Installed yesterday, cannot replicate this issue... your system maybe?
I was worried for a bit when I found this as "installed" in my update history, however it hasn't affected my system as it has affected yours. I'll be on the lookout for such updates, though.
Yeah I just checked right now, everything is fine for me as well.
Edit: I see some people mentioning SP1, was this update indeed SP1? Or are the people who have it, getting it from the leaked version that got leaked a little while ago?
Problem Solved
1º) Install KB980408 normally
2º) Delete* the following registry entries:
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{2112AB0A-C86A-4ffe-A368-0DE96E47012E}]
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{2112AB0A-C86A-4ffe-A368-0DE96E47012E}\\PropertyBag]
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{491E922F-5643-4af4-A7EB-4E7A138D8174}]
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{491E922F-5643-4af4-A7EB-4E7A138D8174}\\PropertyBag]
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{7b0db17d-9cd2-4a93-9733-46cc89022e7c}]
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{7b0db17d-9cd2-4a93-9733-46cc89022e7c}\\PropertyBag]
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{A302545D-DEFF-464b-ABE8-61C8648D939B}]
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{A302545D-DEFF-464b-ABE8-61C8648D939B}\\PropertyBag]
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{A990AE9F-A03B-4e80-94BC-9912D7504104}]
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\FolderDescriptions\\{A990AE9F-A03B-4e80-94BC-9912D7504104}\\PropertyBag]
3º) Logoff or restart
* Double click on attachment .reg to automatically clear the entries
Hi!
I'm from Spain and i Installed the horrible update from Microsoft.
I have the same problem that JeevusCompact.
In my Windows 7 x64 spanish.
I wait a solution from M$.
JeevusCompact my hardware is:
-Intel Core2 Quad Q9300 @ 3.0 Ghz
-ZeroTherm Nirvana 120
-Asus P5K-E
-4 GB Mushkin Extreme DDR2-800
-Asus Geforce 8800GT 512 MB Asus GeForce EN8800GT/G/HTDP/512M/A
-2xHDD:
Seagate 500 GB
Seagate 320 GB
-Lector DVD LG
-Pioneer DVR-215
-Corsair VX550
-Cooler Master CM690 Dominator
I don't know what we have in common... :S software, hardware?
Thanks, see you
1 - 20 of 30 Posts
