Which should i pick? i want the most bang for the buck and will be OC'ing a Q8200 with this and want to get more than 3.3Ghz+
please help me choose!
Originally Posted by ben h ![]() id go with the mugen also did u look at the sheet i posted for bios settings |
CPU =q8200
Motherboard = EP45-UD3P
BIOS Version =FD
Ram = Kingston 4GB
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: turbo
CPU Clock Ratio .............................: 7X
Fine CPU Clock Ratio.....................:
CPU Frequency ..............................:3.15ghz (450X7)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: enabled
CPU Host Frequency (Mhz) ............:450
PCI Express Frequency (Mhz) .........:100mhz
C.I.A.2..............................: disabled
DRAM Performance Control
Performance Enhance..................:standard
(G)MCH Frequency Latch...............:auto
System Memory Multiplier ..............: 2.0D
Memory Frequency (Mhz) ..............: 900
DRAM Timing Selectable ................:auto
Standard Timing Control
CAS Latency Time........................:5 auto
tRCD .............................................:5 auto
tRP............................................... ..:5 auto
tRAS.............................................. :18 auto
Advanced Timing Control
tRRD...........................................:3 auto
tWTR..........................................:3 auto
tWR............................................:6 auto
tRFC...........................................:52 auto
tRTP...........................................:3 auto
Command Rate (CMD) ....................:0 auto
Channel A
Static tRead Value.........................:8 auto
Channel B
Motherboard Voltage Control
CPU Vcore….………..............1.23750V............:1.250 V
CPU Termination…..... 1.200V*...............:1.2V
CPU PLL…………………....1.500V*.......:normal
CPU Referen.…………....0.760V*...........: normal
MCH/ICH
MCH Core…………….....1.100V...........:1.3V
MCH Reference….…….0.760V............:normal
MCH/DRAM Ref.…......0.900V..............:normal
ICH I/O……………….....1.500V............:normal
ICH Core…………...……1.100V...........:normal
DRAM
DRAM Voltage ……....1.800V............:1.8V
DRAM Termination .…0.900V............:.9V
Channel A Reference 0.900V............: normal
Channel B Reference 0.900V............: normal
Originally Posted by jetplane48 ![]() well, does anyone have a graph showing the temps and the CFM and the DBA and that sort? |
