a little background (its needed)- both rads are blowing out right now (240 is blowing out the side) and i was thinking about make the top 360 rad blow in (since its right before the blocks) and the 240 blow out (since its right "after" the blocks). I also plan on getting a 5970, and of course, watercooling it so my questions are as follows
1. should i have the 5970 before the 5870?
2. what block for the 5970?
3. how should i run my loop?
right now i have
res/pump->240rad->pump->360rad->cpu->gpu->res
idea with the 5970
res/pump->360rad->cpu->5870->pump->240rad->5970->res/pump
the lengths of tubing would be about the same so i dont have to take that into consideration, i know i'm going to want the best temps on the 5970 so i can easily OC as high as possible(at least to 5870 clocks)
thanks for the help!
right now i have
idea with the 5970
