1 - 3 of 3 Posts
Okay... another tricky one here.....<br><br>
B/G - A new single thread game that I play - by setting affinity to core1 and priority to REALTIME I can gain fps and smoothiness.<br><br>
Now what I want - because I cant be ar$3d messing with individual tasks everytime - is a programme that I can run that will set all current tasks to a single core.<br><br>
Then I can run my game and set it up as I want knowing it is truely dedicated to one core only.
Administrator
Unfortunately you will have to do this manually i beleive. Any background tasks or Apps you wish to Assign to a seperate core will have to be done under Processes in the task manager. <br />
<br />
1. Open up task manager. CTRL,ALT.DEL <br />
2. Go to the Processes TAB. <br />
3. Find the Program Process you wish to move and right click on it and select ''Affinity''
Thanks Enterprise - I was just being lazy and trying to avoid that process..<br />
<br />
ps I'm catching up with your folding rank!
1 - 3 of 3 Posts
